I updated my e410 cn pilot radio to release 3.11.2-r2 last night. After the reboot, the radio never came back to cnmaestro. I have been able to ssh into the radio and I can see that it is on the new 3.11.2-r2 release and that it is accepting clients. While I am in the radio, via ssh, I am able to ping an external ip address but can not ping anything via name. The name server is pointing to my local router, as it always has been, and should be fine.
Obviously the reason it can not talk to cnmaestro is that it can't resolve the name.
Anyone else experiencing this? Any idea how I can resolve this issue without having to go to a static IP configuration?
thanks for doing a round of troubleshooting already to narrow this down. Could you please run 'show ip name-server' from the CLI and send us the output?
Also, is your router reachable through vlan 1 on the AP? If so, on the CLI under 'interface vlan 1' if you add 'ip dhcp request-option-all' (if that line does not exist) does that change the behaviour?
Hi Mike, Please email me tech-support of AP after upgrade. This will help us to know if DNS servers are learnt by device. My email id is shashank.tadakamadla@cambiumnetworks.com
I had this problem after an upgrade and the radio lost it's default gateway. Check that.
How was the issue resolved?
Re-adding the default gateway into the Vlan. It had a static entry
thanks. so the gateway was static, but that was lost on upgrade? Could you please share your config (either the whole thing with private info such as ssids/passphrases deleted, or just the section relating to interface-vlan) and what was the old software version before upgrade to 3.11.2?
Backwards compatibility and continued connectivity is very important for us to maintain, so it is concerning to see an AP lose connectivity on upgrade and we want to root-cause and fix this asap. Thanks a lot for your help!
"show ip name-server" results in just simply a return..... nothing returned.
LowerLevel(config-vlan-1)# ip dhcp request-option-all LowerLevel(config-vlan-1)# ping google.com ping: bad address 'google.com'
LowerLevel(config)# ping 4.2.2.1 PING 4.2.2.1 (4.2.2.1): 56 data bytes 64 bytes from 4.2.2.1: seq=0 ttl=56 time=23.304 ms 64 bytes from 4.2.2.1: seq=1 ttl=56 time=23.291 ms
So to answer your question, no the behaviour did not change
More info:
LowerLevel(config)# show ip dhcp-client-info VLAN-1: ------- ip=10.10.10.111 siaddr=10.10.10.1 subnet=255.255.255.0 mask=24 router=10.10.10.1 dns=10.10.10.1 hostname=LowerLevel domain=centralpark.local broadcast=10.10.10.255 lease=3600 serverid=10.10.10.1 opt53=05 opt58=00000668 LowerLevel(config)#
LowerLevel(config)# show config ! no management telnet management ssh management user admin password (removed by Mike) no management radius-auth management http port 80 management http management cambium-remote management cambium-remote validate-server-cert management https management https port 443 led lldp no poe-out country-code US wpa2-handshake-retry 4 4 wpa2-handshake-timeout 100 500 1000 wpa2-handshake-log-level 4 placement indoor ! wireless radio 1 no shutdown channel auto channel-width 20 channel-list all-channels data-rate unicast 1b 2b 5.5b 11b 12 18 24 36 48 54 data-rate non-unicast highest-basic power auto no airtime-fairness antenna-gain 5 beacon-interval 100 off-channel-scan dwell-time 50 auto-rf channel-selection-mode interference auto-rf chan-hold-time 120 auto-rf interference-diff-threshold 10 auto-rf packet-error-rate-threshold 30 auto-rf channel-utilization-threshold 25 multicast-to-unicast max-stream 40 multicast-to-unicast max-stream-per-client 25 mesh-xtnded-dev-list wmm-parameters downstream txoplimit vi 3008 wmm-parameters downstream txoplimit vo 1504 wmm-parameters upstream txoplimit vi 3008 wmm-parameters upstream txoplimit vo 1504 ! wireless radio 2 no shutdown channel auto channel-width 80 channel-list all-channels data-rate unicast 6b 9 12b 18 24b 36 48 54 data-rate non-unicast highest-basic power auto no airtime-fairness antenna-gain 5 beacon-interval 100 off-channel-scan dwell-time 50 auto-rf channel-selection-mode interference auto-rf chan-hold-time 120 auto-rf interference-diff-threshold 10 auto-rf packet-error-rate-threshold 30 auto-rf channel-utilization-threshold 25 multicast-to-unicast max-stream 40 multicast-to-unicast max-stream-per-client 25 mesh-xtnded-dev-list wmm-parameters downstream txoplimit vi 3008 wmm-parameters downstream txoplimit vo 1504 wmm-parameters upstream txoplimit vi 3008 wmm-parameters upstream txoplimit vo 1504 ! wireless wlan 1 ssid Guest no shutdown vlan 10 security wpa2-psk no protected-mgmt-frames passphrase (removed by mike) band both dtim-interval 1 max-associated-client 127 band-steer normal mac-authentication policy deny passpoint interworking internet passpoint interworking asra passpoint interworking access-network-type private no guest-access no guest-access redirect http-only ! wireless wlan 2 ssid Private no shutdown vlan 1 security wpa2-psk no protected-mgmt-frames passphrase (removed by mike) band both dtim-interval 1 max-associated-client 127 band-steer normal mac-authentication policy deny passpoint interworking internet passpoint interworking asra passpoint interworking access-network-type private no guest-access no guest-access redirect http-only ! interface eth 1 switchport mode trunk switchport trunk native vlan 1 switchport trunk allowed vlan 1,10 ! interface vlan 1 ip dhcp request-option-all ip address zeroconf management-access all ip address dhcp !
ip route default 10.10.10.1 ! timezone America/Detroit hostname LowerLevel snmp-server ip gw-source-precedence static 1 ip gw-source-precedence dhcpc 2 ip gw-source-precedence pppoe 3 logging syslog 7 ! LowerLevel(config)#
More info:
Scanning through this the config looks ok, we'll load this on an AP and try it out, to make sure.
After that config change of dhcp-request-option-all, did you also do an 'apply' or 'commit' from the CLI to activate the config? ie:
<< needs an 'apply' CLI command done here, CLI commands only go live after an apply/commit>>
Also, what version did you upgrade from? you can check the older version from the CLI with 'show boot', the backup software version will be what you upgraded to 3.11.2 from.
Thanks for the help..... since I never use the CLI I didn't know I had to do the "apply"...... hopefully what I am doing now is helpful.
LowerLevel(config-vlan-1)# ip dhcp request-option-all LowerLevel(config-vlan-1)# apply [Apply OK] LowerLevel(config-vlan-1)# show boot Active Software Version : 3.11.2-r2 Backup Software Version : 3.5.2-r4
LowerLevel(config-vlan-1)# LowerLevel(config-vlan-1)# ping www.google.com ping: bad address 'www.google.com' LowerLevel(config)# ping 4.2.2.1 PING 4.2.2.1 (4.2.2.1): 56 data bytes 64 bytes from 4.2.2.1: seq=0 ttl=56 time=22.693 ms 64 bytes from 4.2.2.1: seq=1 ttl=56 time=22.902 ms ^C --- 4.2.2.1 ping statistics --- 2 packets transmitted, 2 packets received, 0% packet loss round-trip min/avg/max = 22.693/22.797/22.902 ms LowerLevel(config)#
More info:
Thanks.
can you please delete the default gateway from config, and have that also learnt from DHCP:
Looks like we have an issue where the older firmware used to allow static gateway but DNS from DHCP and newer ones dont.
It appears that the gateway static precedence of 1 means that it looks for the gateway as static before looking at dhcp. When I manually put in a static gateway, even though I'm using DHCP, it worked. When I deleted the gateway, it also worked.
So I tested this theory by creating a bad gateway and with the gw-source-precedence static set to 1 I could not ping google.com. As soon as I change the static precedence to 5 (just to make it a higher number than what the dhcp was set to) I was able to ping google.com again.
So it appears to look for the gateway based on this precedence number and by default must be treating static as a higher level than DHCP.... since I was using DHCP the static gateway must have been wrong.
To solve when using dhcp, for now do ONE of the following:
