Solar power option?
How to connect connectorized/unconnectorized ePMP1000 to a 24V DC Power Source?
Are you trying to power an AP or STA/CSTA?
Both. We have a solar powered station doing ptp uplink and ptmp to customers. At the moment we use Mikrotik. The system runs at 24V.
Stefan: No issue at all with STAs but the APs have a minimum 23VDC input voltage so you need to make sure that your 24VDC battery system after voltage drops is at or above 23VDC.
We are looking at doing a solar power option for an Epmp1000 AP ptp, and possibly ptmp option to a farm yard.
Shoot back to the house about 1/4 mile.  Also, some places by a lake in hopes of getting up to 12 homes.
does anyone have experience with a solar power and mounting AP's on the same pole.  I live in MN so cold winters
and short daylight will probably force us to use more batteries.
Dave
For the guys running 24VDC ever think of running 5 of the 6 volt deep cell batteries?
@David,Check out Tycon Power. They have some nice solar setups . They also have some turbine options as your not getting a ton of sunlight. PM me if you want more information.
From my all DC site (while not solar FYI) I found that the APs can't boot/stay on at 20vdc with <50 foot cat5 runs.  23vdc should be more more than enough.
If you regulate the power from the batteries (charging ~27v, dischanging <19v) and always put out 24vdc you should be perfectly fine with shorter cat5 runs.
You can use this for your AP's.
http://www.balticnetworks.com/tycon-power-9-36vdc-in-24vdc-out-19w-dc-to-dc-converter-and-poe-inserter.html
and for epmp2000 56v? i have a battery 24v.
thanks
Power everything from a DC Netonix switch. They happily convert 24v DC input to 48v POE.
Is posible link?
This is what we use on most of our towers:
https://www.netonix.com/wisp-switch/ws-8-150-dc.html
