Hi, one of our customer need to uso a vpn with a sonicwall client; it seems that the cambium nat does not permit to the vpn to login into server. It happen with cisco vpn client too; I tryed to enable the dmz but this not made changes. Maybe the only way to solve it is to disable the nat and use pmp450 as bridge.
Is there a way to solve it without disabling the nat ?
nobody has the same issue? i think the NAT of the cambium sm sometime is a a problem; the vpn doesn't work....and SIP connection from outside doesn't walk thorugh the nat; the only way to fix it is set the SM in Bridged Mode, and intall a 3rd party router....; but i would like to find the solution without installing more hardware....
I have a client who again requires VPN using IPSEC (for an Aruba box) and for whom previous workarounds do not work.
NAT is working for all traffic on a laptop but VPN for Aruba is not coming up. There is no local management console on the Aruba so I have no diagnostics.
Client cannot set up VPN on laptop to test either.
