Hi all, I’d like to ask you if there is a way to make the SPLASH resizable at the login of the voucher.
SPLASH has problems on smartphones and iPads. These problems are greater if the screen of smartphone and iPad are set on vertical way.
Everything’s ok on PC.
All the best,
