Switching between active and inactive software versions
At the risk of a rookie question, how do you switch between active and inactive software versions on…
  • An XV2-2 using either the web interface, or SSH
  • In cnMaestro cloud (essential not X)
    I can’t find that in any documentation so far, so any advice on how or where to find that information would be helpful.
Run “service boot backup-firmware” command from Remote CLI on cnMaestro, or AP CLI (ssh)
Thank you @Anandakrishnan
Feature request: Would be great if there was a more obvious way (i.e. menu option requiring super admin level and with a “are you sure you really want to do this” confirmation). No point having two firmware versions if you can’t access them easily when you need them.
