I've noticed that after Elevate SXT, its antenna gain is set at zero. Do I have to set it to 16?
good question and good observation, in the antennas of Cambium, the Force 180 and the Force 200 comes the gain of the antenna, presumably should be put, to see if some clarifies, Cambium, a greeting.
Doing Elevate on LHG, I've seen that parameters is set to 24 and also on airGrid is set to 23 or 27 (depending on model)
On SXT, as I said, is default set to 0
