Installed WM4 on Window 2008 Virtual Machine using vwware.
Started OK but when I applied the license gives me a “Systems Error 5” on the machine, and on the brower at the client shows
Cambium Networks Wireless Manager
An internal server error has occurred
Wireless Manager may not be running.
A licensing error may have occurred. Check the startup license log for more details.
Licensing Manager says all OK
License server status: 27000@WINWBP13
License file(s) on WINWBP13: C:'Cambium’LicenseManager’FLEXnet’license_files’Cambium_Networks_WiBB_License.lic:
WINWBP13: license server UP (MASTER) v11.6
Vendor daemon status (on WINWBP13):
motocnpy: UP v11.6
Feature usage info:
Users of WMServerV4: (Total of 1 license issued; Total of 0 licenses in use)
Users of WMEMSPackV4: (Total of 10 licenses issued; Total of 0 licenses in use)
_
Anyone had the same issue ?
Gordon,
Did you install WM 4 and the license files with “Administrator” privileges?
Are you having an issue running WM 4? Or are you having issues installing new licenses?
