Hola a todos.
Acudo a este foro para solicitar ayuda, estaba revisando el log de unos equips cambium epmp5c, noto que cada cierto tiempo aparece el error:
GPF: tdd_gpf_send tdd_maptx_add_gpf error
Alguien sabe que significa? Curiosamente aparecen solamente en los radios que tengo como AP.
Aqui un log:
Aug 28 14:49:05 3 DEVICE-AGENT[2603]: Not received PONG for the last ping (3) Aug 28 14:49:22 3 DEVICE-AGENT[2603]: Not received PONG for the last ping (4) Aug 28 14:52:26 3 kernel: [31315.780000] GPF: tdd_gpf_send tdd_maptx_add_gpf error Aug 28 14:52:41 3 kernel: [31330.690000] GPF: tdd_gpf_send tdd_maptx_add_gpf error Aug 28 14:53:01 3 kernel: [31350.260000] GPF: tdd_gpf_send tdd_maptx_add_gpf error Aug 28 14:56:50 3 kernel: [31579.620000] GPF: tdd_gpf_send tdd_maptx_add_gpf error Aug 28 14:57:00 3 kernel: [31590.070000] GPF: tdd_gpf_send tdd_maptx_add_gpf error Aug 28 14:57:24 3 kernel: [31614.150000] GPF: tdd_gpf_send tdd_maptx_add_gpf error Aug 28 14:59:37 3 DEVICE-AGENT[2603]: Not received PONG for the last ping (1) Aug 28 15:00:04 3 DEVICE-AGENT[2603]: Not received PONG for the last ping (2) Aug 28 15:00:20 3 DEVICE-AGENT[2603]: Not received PONG for the last ping (3) Aug 28 15:00:38 3 DEVICE-AGENT[2603]: Not received PONG for the last ping (4) Aug 28 15:01:01 3 DEVICE-AGENT[2603]: Not received PONG for the last ping (5) Aug 28 15:01:01 3 DEVICE-AGENT[2603]: Missed 5 consecutive PONGS, disconnecting with server Aug 28 15:01:21 3 DEVICE-AGENT[2603]: callback_websocket: LWS_CALLBACK_CLOSED Aug 28 15:01:21 3 DEVICE-AGENT[2603]: Attempting (re)connection in 5 seconds Aug 28 15:03:31 3 kernel: [31980.580000] GPF: tdd_gpf_send tdd_maptx_add_gpf error Aug 28 15:04:15 3 DEVICE-AGENT[2603]: Not received PONG for the last ping (1) Aug 28 15:04:40 3 DEVICE-AGENT[2603]: Not received PONG for the last ping (2) Aug 28 15:05:02 3 kernel: [32071.810000] GPF: tdd_gpf_send tdd_maptx_add_gpf error
Aclaro, uso firmware 3.5. Y los tengo configurados como TDD PTP.
Tendrá algo que ver con que los equipos se desenlacen cada 4-5 días, y en ocasiones alguno deja de responder en el puerto lan, por lo que tengo que reiniciarlos de manera inalambrica, por esa razón, he empezado a reiniciarlos regularmente en las madrugadas cuando no hay tráfico y así evitar que se bugueen solos.
