I have a XV2 AP and the charger does not connect in the WPA2/WPA3 mode and I have to set it back to WPA2 in the WLAN settings. It seems to be a problem with the charger. Does anyone have workarounds or hints?
Create separate wlan with wpa2 only on 2.4 GHz.
Lot of iot devices got problem with wpa3 or mixed wpa2/wpa3 and sometimes with 5 GHz
My inlaws have a bunch of mini computers that can’t even see the SSID when you enable WiFi6. Had to make an SSID that has it disabled, for those computers.
