It's a question that comes up a lot...I have a multicore radio (PTP820C, PTP820C-HP, PTP820F....) and in the configuration - and even earlier than that in Link Planner - I am faced with a choice. What to I chose, and why should I chose it? Let's start with the Link Planning. Let's say you selected a PTP820C radio at 11 Ghz for a seven mile clear LOS link. You have selected the radio. If you are in the US, you might have selected PTP820C (Wide) for the hardware. Maybe if you are in Canada or other parts of the world, you didn't get the "Wide" choice. That all has bearing on what is offered next in the configuraiton. In Link Planner there is a field called "Ethernet Configuration", and in my US based link, it offers the following choices:
1. Single Ethernet (MCABC)
2. Multiple Ethernet with LAG
3. Multiple Ethernet without LAG.
"What the heck do those mean?" you might ask. Well, lets start with the the Acronyms, we network types love our acronyms.
1. MCABC - that one stands for "Multi Core Automatic Bonded Channel". You'll see you don't get that option if you put two PTP820S (single core) radios onto the same antenna, only with a true multi-core radio like the PTP820C and PTP820C-HP (and any future multi core radios we might invent). In my fictional PTP820C link, I chose the wide radios (that means they occupy nearly 80 MHz of spectrum per core, per direction) and if I have good enough signal into the far end, I could see as much as 650 Mbps per carrier - that works out to 1.3 Gbps of capacity in each direction. If my aim is to squeeze every bit of throughput out of that link, I have to consider a few things.
1. MCABC is really good and really efficient - nearly lossless - in bonding thos carriers, but...and this is a big but. My PTP820C or PTP820C-HP radios can only support 1 Gbps full duplex to any one interface. If I chose to bond them with MCABC, I'd lose access to 150 Mbps in each direction or 300 Mbps aggregate. MCABC makes a lot of sense if I'm either in an area that does not support 80 MHz channles, or in a band like 23 Ghz or 6 GHz that only allows up to 60 Mhz wide channles. So there is my first decision point, if channels are 60 MHz or smaller, strongly consider MCABC. There is a license key for MCABC, link planner will add it to the Bill of Materials if you chose it.
2. Multiple Ethernet with LAG. This choice implies that each of the two radio cores will send data on a seperate ethernet cable (you'll need an extra port activation license - Link Planner should add that to the BOM along with any additional cabling needed). The assumption is that the links will be bonded by switches they are connected to. Chose the switches wisely, the best are able to keep about 92% of the capacity while the worst could drop that number to 72%.
3. Multiple Ethernet without LAG. In this scenario the two paths are kept seperate. Maybe used by different users. In one case I worked with, a service provider was able to get access to a desirable city owend tower if they gave the 911 emergency system a seperate path at the same time. That's a scenario where this makes sense, although I'm sure there are more but you get the idea. Each radio path is it's own thing and the two will likely never meet. In this scenario you'll also need a licese and cabling to enable that second data path, and once again Link Planner should take care if it for you if you make the right choices.
I hope this adds a bit of clarity to what can be a confusing decision.
