To verify the distance and transportation.
Hello, how are you?
I have a Cambium 4600c setup using a 160 MHz channel over a distance of 37 km, with a 70/30 traffic split.
The issue is with the frame size; it is set to 5 ms, and I cannot change it. Also, the ePTP mode isn’t working for me.
My throughput is 450/100, and the frequency is clean. Are there any solutions?
Hello @marckos_eed welcome to the Cambium forums!
The frame size cannot be changed on e4k 6GHz. It’s fixed at 5ms.
Your link is 37km. ePTP is limited to a maximum distance of 32km.
You may want to try using an 80MHz channel width and see if your aggregate throughput is any better.
What size/gain dishes are you using, and what is the RSSI and SnR on each side?
