Transmission steps between ePMP force 300-16 and XV2 access points
I wanted to deploy two ePMP force 300-16 in point-to-multipoint, both are connected with cambium access points XV2. I would like to know how the radio transmission between the ePMP force 300-16 and the XV2 access points works. Can anyone help me?
How are the XV2 units connected to the f300?
Iā€™m not sure what you mean by the radio transmission between the ePMP and XV2. You would typically just connect the XV2 to the LAN of the F300 via an ethernet cable. So, no radio transmission occurring between the XV2 and F300.
I think I see what you mean.
The F300 cannot connect to an XV2.
The XV2 is a wifi access point, whereas the f300 is meant for fixed wireless and does not use standard wifi protocols.
You would need an ePMP2000/3000/4500 to connect an F300.
The XV2 is meant for client connections.
So, the proper design would be
ePMP AP <-wireless-> ePMP F300 <-ethernet-> XV2 <-wireless-> Client devices
Thank you for your contribution
