Transmit Frame Spreading
Please can someone explain this feature and how it is used/manipulated?
It takes the sync beacons which are usually like a metronome and staggers them in a pseudo random pattern.
It’s usefull if you have a lot of AP’s looking at the SM and the SM has a hard time locking onto the beacon of an AP it wants to register to. This will happen if another AP is on or near the same frequency and is just as loud or louder as the preferred AP.
The randomness of the beacon comes at a slight performance hit, so its recommended to not use it unless your SM’s are having a hard time registering to their favorite AP.
That’s the non technical description.
thanks for the info, quite informative.
