I am trying to connect two Cambium Force 200 devices together to send camera footage from a garage to a house.
The first Force 200 I had set up as an "Acccess Point" and the second Force 200 I had set up as a "Subscriber Module" and the two devices can connect to each other very easily. I can reach the SM from the AP but I cant locally connect to the SM via a switch.
How I have the mock setup as is there is ethernet coming from my office and into the AP then the AP is connecting with the SM. The SM is plugged into a switch and in that switch I have a camera but I cannot see anything past the SM.
I have checked the cat 5 and the switch, both of these are fine and I feel that I am just missing a step. Does anyone know what I might be overlooking/not doing to get the SM to transmit data?
Hello, I have force 200 with firmware version 2.4.3-RC16 is there any need to upgrade this firmware ? and how do i do that if it is required to upgrade ?
Yes, you should upgrade. Many new features and improvements have been made. The current release on the support web site is 2.6.2. Here is the URL to get the software:
