Trouble importing 650 mibs into prtg
Hello,
     I am trying to use Paessler MIB importer v3 to import Cambium ptp 650 mibs into prtg. I get an error "DEFINITIONS expected" I have tried this on several different machines and had the same result.  Anyone have a solution?
Hello,
You will have to use the file "CAMBIUM-PTP650-V2-MIB". Please note that there is no extension. Importing the file "cambium-ptp650-v2.txt" would give the error you mentioned.
..Ram
That was it… Thanks Ram!
