Anyone? @anon89030143? I really want to use the cnpulse/sync included in the switch as I saw improvements on the sector radios when it works…but it is to frequent that it becomes “not in sync” and its quite annoying to keep having the AP stop transmitting to the SMs.
We have not heard issues from others of a connected cnPulse to a TX2K switch having intermittent In-Sync status.
Once power is enabled to the cnPulse, which you have, and the GPS module has established a satellite lock to the constellation, the TX2K will receive the valid sync pulse and generate the “In-Sync” status.
There are a couple things you can check in your cnPulse installation:
Ensure that the location of the cnPulse has a clear view of the sky.
Overhead trees or surrounding buildings could impede a sold satellite lock.
A typical satellite lock should have a similar GPS status (notice the number of satellites in view, and in use):
For a cnPulse installed in a blocked or partially blocked location, you will notice a reduced number of Satellites in View.
This could cause a intermittent loss of the sync signal, as the cnPulse loses the satellite lock.
A suggested remedy would be to relocate your cnPulse to a higher location or to a spot for a clearer sky view.
v4.3r3 is the latest SW release, which includes the Cambium Sync fix that now properly reads and displays the GPS data from both “old” (pre-2021) and “new” (post 2021) cnPulses.
Prior to v4.3r3, the TX2K could not properly display the GPS data on the “new” cnPulse due to its internal FW differences.
@Jonchau Thank you for your reply… both switches that are experiencing this issue are both connected to a cnPulse that has excellent clear sky view, both tower locations are very remote with zero trees or buildings by them.
Both locations do the exact same thing, the sync pulse is enabled, works great and then randomly goes to not in sync… I disable and then enable the cnpulse power state and then it goes back to In-Sync, until the next random not in sync comes along. Both sites have epmp 3000 radios set to cmm in radio config page… Please advise
Hi there,
I am reopening this thread, as we are experiencing exactly the same issue.
The Matrix we have is TX2012RP-B44B00 and the software version is the latest one 5.0.3-r4.
We loose sync without any reason (cnPulse is installed on a high spot with clear view, seeing more than 15 satellites), and power off / on from the interface actually brings the sync in again.
Did you find any solution to this issue, or at least a workaround (such as automating the switch off / on regularly)?
THanks !
I don’t remember seeing an official solution with the cnPluse, but I ended up using a PacketFlux SyncBox instead of a cnPlus on my cnMatrix. Haven’t seen the GPS issue since installed two years ago.
