I need help to get information about TX Spcaing on PTP810, can we change TX Spacing from 154MHz to 161MHz without replacing hardware? because device already installed on site.
Maybe any solution or somebody have same case and resolved it.
Thanks for your question. Since software release 810-01-10, it is possible to configure PTP 810 Tx Frequency and Rx Frequency independently. There is only a question of whether the frequencies you need to use are in the ODU's (Outdoor Unit) supported specturm.
What is yourrequired operating frequencies for the link with the new 161 MHz spacing?
Dear Cambium Team, I can’t download firmware because Chasis Serial Number is not in-warranty, as capture bellow. I hope you have any solution for problem solving immediately. Thanks
