Does this product have a low voltage shutoff, e.g. if voltage drops below a specified value, the unit shuts down until voltage returns?
The current TX1012-P-DC does not have this capability. However we are discussing this feature internally and it is very likely we will move forward with this enhancement.
I look forward to v2.
Right now I can’t connect this directly to battery, I’ll need to put a low voltage disconnect module between the switch and the battery, at additional cost unfortunately.
It would also be great to be able to view voltage, current information also.
Yes, I agree with you that missing this functionality is unfortunate. As you’ve requested , when we address this issue we will also have the ability to view the current voltage, set thresholds and so on.
