If you run two ePMP units in this band with 40 MHz channels you will not end up with the recommended 5 MHz guard band. However, you get the benefit of having likely more clean sprectrum. Have others experimented with this and what were the results. This will be using GPS sync radios, 75/25 and 2.5ms frames.
