Unable to configure 256-bit Key on CnArcher 1.1.16
Unable to configure 256-bit Key AES on CnArcher 1.1.16.
On previous version of CnArcher works properly.
The error:
I write my 32 characters key on PSK Security Settings but there is appears this message:
"Validation Error, provide valid custom 256-BitKey"
If I write a key minor 16 characters, the CnArcher saves key properly.
Kind regards
@Telemar, thank you for highlighting this bug.  It will be fixed in the cnArcher 1.2 release.
cnArcher should allow up to 16 hex characters for the 128-bit key and up to 64 characters for the 256-bit key.  Currently, both are incorrectly being restricted to a length of 15 hex characters.
Thank you Emilio!
@Telemar, the cnArcher version 1.2.4 beta release is available.  This isssue has been resolved.  Please let us know if it's working smoothly now.
cnArcher version 1.2 Release notes
http://community.cambiumnetworks.com/t5/cnArcher/cnArcher-v1-2-beta-available-for-Android/td-p/95413
Hi Emilio!
I've already installed it and it works well.
Thank you so much
