After sitting in my office , I set up the Maestro account and whoa and behold , the 3 ( One has a dup IP Address I will resolve on site later today ) AP's showed up after adding the serial numbers !
Latest code was just applied as it was running 3.8 ? out of the box brand new .
2 configs :
192.168.1.10 = configuration Base
192.168.1.12 = configuration 1 Client
Note :
192.168.1.11 Client - Dup IP address offline
192.168.1.13 Client
All 3 of the clients are programmed exactly the same !
we can see wlan profiles for mesh base and mesh client. we don't see any wlan profile for wireless clients to connect it. the clients or wried clients or wireless clients.
it will be great if you can share the ap techdump for these 2 aps. you can download ap techdump from cnMaestro (screen capture is attached)
I just got them up and running yesterday afternoon ( 4 blue lights and passing traffic ) as I recreated 2 of them as one had a dup static IP address and the other was lost in DHCP land . I have them up on Maestro in generic config as My plan today is to review and update them . I used Maestro to upgrade to the latest code as well as I will review building a template and re installing the template on the units for management purposes and ease of use ( learning curve as I go here to the E410 ) , also 2 Need static IP addresses assigned and an SSID change was asked for last night as well . I disabled the 2.4g network as they will never use them . My plan today is to review the set up , install a guest network and make sure that everyone is logging in to the correct ap's etc.
One issue I DO see is no clients logged in . I know its early but I saw that last nite as well . Is there something I need to set up or is it just that 5 minute rule where the clients must be logged in for 5 minutes or they won't show up ?
Yes, once you push the config from cnMaestro, AP current config will be overritten with cnMaestro based config. The "etc.zip" is not a complete techsupport dump. Please share the complete techsupport dump after pushing the config from cnMaestro.
