I’m running 10.3.2 SM-DES in a 900MHz SM and I’ve noticed a Radio Calibration button under the general config tab … I don’t see it on any other SM running the same ver SW… anybody else get this and if so how do you use it?
it only appears when the radio loses its calibration config (for whatever reason) or when a default plug is plugged into the unit. check here OLD URL for appropriate calibration settings for the antenna.
