I have problem upgrading out 430SM’s from 11.2 to a newer version.
Have tried both 12.1, 12.2.2 and 13.1.1 on the AP.
Have CNUT 4.5.3.
CNUT says: Auto-Update Started (Status: 120) and then: Failed to set max file size (status: 256).
Upgrading PMP100 and PMP450 is ok.
The Release notes for 13.1.1 says:
“Auto update does not work when upgrading PMP 100 SMs and 5.4GHz PMP 430 SMs from 11.2 to 12.1. Workaround is to manually upgrade the SMs. Once on 12.1, auto upgrade will work.
This problem has been resolved in CNUT version 4.5.2.”
Martin,
With the version 4.5.3 of CNUT, is this the Linux version or the Windows version? If it is the Windows version, what Operating System are you running on? (e.g. Windows 7, Windows 8 64-bit) Do you have any firewall or anti-virus installed on the machine with CNUT?
* Do you have more that one network card on the PC or laptop you are using?
* Do you have specific hardware selected and what order is it in, on CNUT? (e.g. are P10 ahead of P11 radios)
* What is the order of the CNUT packages you have?
* Can you share the CNUT log as well as the AP/SM EVent log of the radios that are having issues?
Hello.
It’s the Windows version of CNUT. OS Windows 7 64-bit. No active firewall.
I have been using Canopy since 2008, and have upgraded all versions of hardware, PMP100 5,7 - PMP450 5,4 and 5,7, PMP450 without any trouble.
But now I have trouble autoupgrading PMP430, both 5,4 and 5,7 SM’s, to a newer fw than 11.2.
One network card.
Have tried different order of the hardware in CNUT.
Package order: OFDM, MIMO, PMP100, CMM
CNUT LOG:
04/11/14 07:29:51 INFO Host: AP:[10.50.20.21]LUID:[8];ESN: 0A003EB00AB9;Message: Auto-Update Started(status:120). SM:(MAC=0A003EB00AB9 )
04/11/14 07:29:52 INFO Host: AP:[10.50.20.21]LUID:[9];ESN: 0A003EB00320;Message: Auto-Update Started(status:120). SM:(MAC=0A003EB00320 )
04/11/14 07:29:53 INFO Host: AP:[10.50.20.21]LUID:[10];ESN: 0A003EB00BF4;Message: Auto-Update Started(status:120). SM:(MAC=0A003EB00BF4 )
04/11/14 07:31:46 INFO Host: AP:[10.50.20.21]LUID:[6];ESN: 0A003EB05BE5;Message: Auto-Update In Progress(status:132). SM:(MAC=0A003EB05BE5 )
04/11/14 07:31:47 INFO Host: AP:[10.50.20.21]LUID:[7];ESN: 0A003EB00063;Message: Auto-Update In Progress(status:132). SM:(MAC=0A003EB00063 )
04/11/14 07:31:48 INFO Host: AP:[10.50.20.21]LUID:[8];ESN: 0A003EB00AB9;Message: Auto-Update In Progress(status:132). SM:(MAC=0A003EB00AB9 )
04/11/14 07:31:49 INFO Host: AP:[10.50.20.21]LUID:[9];ESN: 0A003EB00320;Message: Auto-Update In Progress(status:132). SM:(MAC=0A003EB00320 )
04/11/14 07:32:15 WARN Host: AP:[10.50.20.21]LUID:[6];ESN: 0A003EB05BE5;Message: Failed to set max file size(status:256). SM:(MAC=0A003EB05BE5 )
04/11/14 07:32:16 WARN Host: AP:[10.50.20.21]LUID:[7];ESN: 0A003EB00063;Message: Failed to set max file size(status:256). SM:(MAC=0A003EB00063 )
04/11/14 07:32:17 WARN Host: AP:[10.50.20.21]LUID:[8];ESN: 0A003EB00AB9;Message: Failed to set max file size(status:256). SM:(MAC=0A003EB00AB9 )
04/11/14 07:32:18 WARN Host: AP:[10.50.20.21]LUID:[9];ESN: 0A003EB00320;Message: Failed to set max file size(status:256). SM:(MAC=0A003EB00320 )
AP LOG:
System Startup
System Reset Exception – Watchdog Reset Cur ExtInt 0 Max ExtInt 0 Cur DecInt 0 Max DecInt 0 Cur Sync 0 Max Sync 0 Cur LED 0 Max LED 1 Cur WDOG 0 Max WDOG 1 Cur EthXcvr 0 Max EthXcvr 1 Cur FEC 0 Max FEC 0 Cur FPGA 0 Max FPGA 2457 Cur FrmLoc 0 Max FrmLoc 0 Cur WatchDog 66 Max WatchDog 9306 RTMLogStats 0 AAState 21
Software Version : CANOPY 12.1 AP-DES
Board Type : P11
Device Setting : 5.4GHz OFDM - Access Point - 0a-00-3e-b0-04-d2
FPGA Version : 112211
FPGA Features : DES, Sched, US/ETSI
04/10/2014 : 07:24:14 CET : : Bridge Core : Flash Image Update OK
04/10/2014 : 07:24:33 CET : : Bridge Core : Reboot from Webpage.
04/10/2014 : 07:24:33 CET : Bridge Core :
System Startup
System Reset Exception – Watchdog Reset Cur ExtInt 0 Max ExtInt 0 Cur DecInt 0 Max DecInt 0 Cur Sync 0 Max Sync 0 Cur LED 1 Max LED 1 Cur WDOG 0 Max WDOG 1 Cur EthXcvr 0 Max EthXcvr 1 Cur FEC 0 Max FEC 0 Cur FPGA 0 Max FPGA 703 Cur FrmLoc 0 Max FrmLoc 0 Cur WatchDog 66 Max WatchDog 10758 RTMLogStats 0 AAState 21
Software Version : CANOPY 13.1.1 AP-DES
Board Type : P11
Device Setting : 5.4GHz SISO OFDM - Access Point - 0a-00-3e-b0-04-d2 - 5550.0 MHz - 20.0 MHz - 1/16 - CC 0
FPGA Features : DES, Sched, US/ETSI;
SM LOG:
Software Version : CANOPY 11.2 SM-DES
Board Type : P11
Device Setting : SM
FPGA Version : 072310
01/01/2011 : 01:00:12 CET : :Timezone set to CET
12/02/2013 : 10:19:29 CET : :Time set
04/11/2014 : 06:46:16 CET : :Reboot from Webpage.
04/11/2014 : 05:46:17 UTC :
System Startup
System Reset Exception – Watchdog Reset Cur ExtInt 0 Max ExtInt 0 Cur DecInt 0 Max DecInt 0 Cur Sync 0 Max Sync 0 Cur LED 2 Max LED 1 Cur WDOG 0 Max WDOG 1 Cur EthXcvr 0 Max EthXcvr 1 Cur FEC 0 Max FEC 0 Cur FPGA 101 Max FPGA 1073 Cur FrmLoc 0 Max FrmLoc 0 Cur WatchDog 33 Max WatchDog 33 RTMLogStats 0 AAState 0
Board Type : P11
Device Setting : SM
04/11/2014 : 06:46:29 CET : :Timezone set to CET
Do you have routable IP’s in your SM’s? If not, I have found that by putting a temporary routable IP into the SM and then having CNUT place it in the root, I was able to Upgrade Selected Element. Then remove the IP and put it in another unit, Update view and the Upgrade selected element. A real PITA but gets things up to date.
