Yes, you can connect port 1-8 of 2010-P to HP switch using RJ45 cable 1000BASE-T. You can also get a copper-SFP transceiver to connect SFP port 9 or 10 of 2010-P to HP switch using RJ45. You don't need to do any configuration in order to use the RJ45.
