I know cnMaestro provides good info and graphs it over time (and over longer intervals via the subscription) but we use PRTG, mainly for notifications. PRTG’s SNMP is v2 Compliant. We also use PRTG to monitor all our other network equipment, graph usage, signal etc. Instead of from the command line, I used the recommended iReasoning program to browse and GET OID info from APs and SMs and I’m getting responses/data back from the radio(s) but I need OIDs that are useful. Am I missing something? I don’t see anything in the latest MIB download for version 20.2.2 that provide data we would like to monitor (RSSI, Modulation Throughput) Does the SNMP for the Medusa 450b and APs provide the same basic info we see cnMaestro graphing? Is there any MIBs out there that I can use SNMP to GET basic info like throughput or RSSI/signal? And I know the subscription version of cnMaestro could replace PRTG but we have other non-Cambium equipment we monitor using PRTG so I don’t want to dump PRTG. Thanks in advance for any feedback, guidance or assistance.
I don’t even know what PRTG stands for, but yes, all the info that cnMaestro graphs is available in SNMP.
Yes, iReasoning works for verification. And we provide the MIBs for download every release. Are you aware there are 3 MIBs? AP, SM and Box (that applies to AP and SM).
Sorry so many questions… but I recommend loading all those MIBs and walking them and you’ll find lots and lots of information. Enjoy!
Thank you - I found what I needed after loading the applicable MIBs and “walk” through.
PRTG is a SNMP based data logger. Like MRTG it connects to equipment via SNMP and stores the data in a database.
PRTG stands for Paessler Router Traffic Grapher and is part of Paessler’s Network Monitoring Suite.
This use to be a Windows only system but they now also have a linux version.
Hello @daviscomputers ,
we do use PRTG to monitor our radios (PTP 820S, PMP 450i AP, PTP 450i and even PTP 670 at some extend). To add the required OID, you need a Paessler MIB Importer for PRTG. You can download it from the link: Import MIB files into PRTG Network Monitor.
If you go to the Cambium Networks download page, you will see MIBs for each firmware version depending on the radio model such PMP 450: Log In / Cambium Networks Support
You will need then to create a custom folder in the PRTG server OID location and add these new OIDs corresponding to the PMP 450 sensors.
You should have some System Admin skills to achieve this.
Sincerely yours,
Niragira Olympe
Yes, we’ve used the PRTG MIB importer for other hardware before. Thanks for the guidance. I’ll import 450MIBS, then add a 450 access point and a 450b just to see how many sensors it creates.
My issue was being unfamiliar with and am still getting to know the iReasoning browser.
Walked through the AP MIB, I must be missing something. There are hundreds of OID and Values/types. Can you provide any OIDs that would be useful to graph. Like interface throughput, SM RSSI, frame and CPU utilization etc. Maybe OIDs of what I see in the cloud WebGUI’s performance tab. I walked a 450 AP and see lots of info about subscriber units and info on the AP. But nothing really that useful. Can you point me to any pertinent OIDs along the line of basic useful info? This would be helpful. Thanks
There are a few MIB packages that must be imported to get all of the OID names. If you are missing any MIB files then you will get a OID listing with missing information
Yeah lots and lots of information in the MIBs. Sorry, @daviscomputers, but I’m going to have to allow the community to support you here.
In the meantime, I’d recommend cnMaestro which is our free cloud or on-premise software that does most all this stuff for you.
I loaded all the MIBs and can see the OID names. It’s just WAY too much to info add to PRTG because we only need to monitor a few aspects of each AP. Our PRTG is licensed but still has a sensor limit. I’m leaning towards just using cnMaestro. My only issue there is how do I get notifications to send a text to a cell phone instead of an email? We use a Google Voice Ph# and PRTG can send SNS texts. That gets the immediate attention of the on-call tech. But unless someone reads this ands knows how to send a text to a google voice phone instead of an email and can respond to this, then I know that’s another post on this forum. Thanks for everyone’s assistance with this.
you can merge the MIB files and trim the unneeded names then drop the full MIBs and reimport the modified ones to PRTG.
The problem with cnMaestro is it does not allow us to select what is logged and what is not. It is also not adjustable for sequence timing. In short it is too ridged. PRTG is way more flexible and has more selectable options.
We are using both MRTG and Cacti for our monitoring systems and have no issues with sensor limits.
