Using cnArcher with no cell coverage
Before I order everything needed for this to work properly, ie powerlink…can I use cnArcher to help align a ptp450b in an area where there is ZERO cell coverage? Thanks
Yes, you can use cnArcher for alignment without cell phone coverage. You can also fully test cnArcher by using any Wi-Fi router that supports bridge mode. If you can access the radio GUI at 169.254.1.1 from the browser on the phone, cnArcher will also work (but cnArcher uses SNMP and not http).
That’s great, thanks for answering.
