Using cnPulse with Force-300 CSM
Can we use cambium cnpulse with force 300-csm if multiple radio of same make installed at same tower.
Hi @AJAY_YADAV, welcome to the Cambium Community. I’ve moved your post into the ePMP product forum, where more people are likely to see it and be able to help.
Thanks but need urgent feedback on this solution
Hello Ajay. I believe the answer to your question is no. The Force300’s are not GPS Synced.
I mean - they are as a client radio, because they follow the GPS Sync of the AP they are connected to. So if you have a ePMP 3000 or 3000L or 2000 AP with GPS Sync, then a Force300csm that is connected as a client follows and sync’s with the AP’s sync.
BUT, if your questions is asking if a Force300csm can be plugged into SYNC, so that it can act as a Synced Access Point, then no - they can’t.
As a matter of fact, Cambium removed the TDD AP (PtMP AP) mode out of the Force300 SM’s altogether, so we can no longer use them as micropop AP’s like we always could previously with all the 1000 & 2000 series non-GPS products. :frowning:
