Summary:
This article demonstrates how to use the “Custom ConfigurationTemplate” for PMP Devices using an API Client
Solution:
This can be achieved by two client applications as stated below:
- Use of POSTMAN application
- Use of CURL command
Method-1 POSTMAN application based template push:-
Prerequisites:
- Create the template on cnMaestro that you wish to push to the PMP devices
- Generate Client ID & Client Secret on cnMaestro
- Configure the Client ID & Client Secret on POSTMAN application
- Fetch the Access Token using POST API and configure it on POSTMAN application
- https://{{server}}/api/v1/access/token
- Below commands are applicable for devices that are already on-boarded not before on-boarding.
Please refer to the below community link that would help us to configure the POSTMAN with Client ID, Client Secret and the Access Token.
Command to execute the template push:
- Use “PUT” command to push the custom template and here is the “Request” format.
PUT https://{{server-ip}}/api/v1/devices/{{device-mac}}
- {{server-ip}} is the IP address of your on-premises server
- {{device-mac}} is the mac address of the PMP device
- Above command might result is an error asking for authorization and content type
Please specify the “HTTP Headers and Body parameters” that is necessary to push the template without any error.
HTTP Headers:
Authorization: Bearer <ACCESS_TOKEN>
Content-Type: application/json
Below is an example:
Body Parameters:
- Inside the Body select “raw”, content type as “JSON format” and configure the template variable in JSON format as stated below.
Format:
“template” : “<Template-Name>”
- <Template-Name> is the name of the template preconfigured in the cnMaestro On-premises that you would like to push to PMP device.
- Once you have Header and Body parameters configured, please click on “Send” button available towards top right hand side requesting for the output.
- The response will be either HTTP 200 (for success), or an HTTP error code with a JSON body (see cnMaestro API User Guide for details). If success and template was specified, a Job is created and started.
Here is an Example Output for success Job creation:
Note:
The Job can be tracked using the job_id, to determine if it completes successfully.
Method-2 Using CURL command to push the Template:-
Curl https://{{server-ip}}/api/v1/devices/{{Device-Mac}} -X PUT -d '{"template":"< template-name>"}' -k -H "Content-Type: application/json" -H "Authorization: Bearer <Access-Token>"
- Server-ip is the IP address of your on-premises server
- Device-Mac is the mac address of the PMP device
- Template-name is the name of the template preconfigured in the cnMaestro On-premises that you would like to push to PMP device.
Access-Token is the access token that we need to fetch from the on-premises server using the below command.
- POST https://{{server}}/api/v1/access/token
Here is an example Output:
Curl https://10.120.200.210/api/v1/devices/0A:00:00:00:00:00 -X PUT -d '{"template":"SM QOS config"}' -k -H "Content-Type: application/json" -H "Authorization: Bearer c27dcdf53ebb6237fad1773d70ba4939da5476c4"
Example Response:
- All available parameters are defined in the RESTful API guide (cnMaestro 2.2.0 RESTful API) which is available in our support web site.
https://support.cambiumnetworks.com/files/cnmaestro/
- Here is the other reference link on how to fetch Performance and Statistics Data.
