Hi, Can we use epmp 3000L with Ubiquiti sector
You can use the 3000L with any 5ghz sector you choose. You will just need to figure out mounting the radio and pickup jumpers of the correct length and connector type, which in this case would be rpsma on both sides.
You can use RF Elements “EasyBracket for ePMP” to mount the 3000L/CSM to just about any Ubiquiti Dish/Sector but you have to drill a hole in the EasyBracket (it’s plastic so easy to do). In most cases you can just use the cable/pigtails that come with the Ubiquiti Dish/Sector when you use the easybracket.
