Hi there,
What does it mean when there are two hexagons instead of one? Please see the pic.
RSSI is good enough.
Hi there,
Hi Sergei,
The fixed beam locations are independent for transmit and receive per node.
So the reason there are two hexagons highlighted is because in this local node instance, the peak RSSI has been detected on different beams for transmit and receive. Most often, the transmit and receive beams are the same but not always.
LINKPlanner can provide a PTP installation report to give a target alignment RSSI for you to compare against.
Hope this helps,
Jack
