I am no expert by any means but am running 8 cnWave meshes… all with a v5000 at the PoP, then two or three v1000’s scattered about. Pretty easy, add a site, add a node, then build a link between the v5000(sector 1 or 2) and the v1000. I have probably built 50 links and it’s not rocket science. A-node is always the v5000 and z-node is always the v1000.
I am having an issue with a link and I have wiped and rebuilt it several times….. even though I explicitly configure to use the v5000 as the a-node and the v1000 as the z-node, it shows up under links in reverse with the v1000 showing as the a-node! Wondering if I accidently clicked or forgot to click a box that would cause that?
Link is flapping and that is the only thing out of the ordinary.
