I created two SSID on the access point and two VLAN’s for each respectively but one of the SSID can communicate with the other VLAN’s on the same network while the second SSID cant communicate, even it can ping its default gateway. What might be the problem.Thanks in advance
Can you please share the product details and the software version used?
