is it possible? The service suplier said that it’s not but their new. this was just introduced in this area and the customers, being used to dial up had some voice. So as you can see, not pleased! any help would be welcome.
James,
Yes we have many customers using VOIP products over Canopy. You can find a white paper at http://www.canopywireless.com/
(click on support -> library -> White Papers) There you will find information on VOIP testing.
Canopy_Support wrote: James,
Sir, if i where to use BHs, is it safe to say that i can break the 5 voice call limit, your coment is higly appreciated.
