Is there a way to just export the tower locations from WLP, so I can import them into another project?
Hi Jesse,
You can export the sites table as a CSV file. Clean this data up in Excel so that it matches the expected CSV format for importing sites and then you can import it. See Import File Formats — Cambium LINKPlanner Online Help (6.2.2) for the import format.
Andy
