What are the best sectors for using the ePMP 4500C as an omni antenna?
Hello,
Has anyone tried using the ePMP 4500C with four 90-degree antennas as an omni antenna? What type of antenna did you use, what cable did you use to connect the sectors, and what were the results?
so, what would be the best sector antenna for this setup?
There are very few people that have one of these radios ATM… I’ve only heard of two people beta testing it… I’m not even sure if it’s available at distributors yet. I’ve not heard any feedback yet either.
Most of the discussion I’ve seen around these are people wanting to use horn antennas with them… either 2x 4x4 arrays, or 4x 2x2 arrays.
KP performance antennas and LINQ antennas would be be excellent choices if you wanted an actual sector panel antenna.
