An ePMP connectorized radio site typically consists of a high supporting structure such as a mast, tower or building for the radio, and an equipment building or moisture-proof enclosure for the indoor equipment (power supply, Cluster Management Module), as shown below in a typical mast or tower installation. If the radio/antenna is to be mounted on a metal tower or mast, then in addition to the general protection requirements, the following requirements must be observed:
- The equipment must be lower than the top of the tower or its lightning air terminal.
- The metal tower or mast must be correctly grounded.
The Cambium 600SSH surge suppressor may be used for 10/100 Mbit Ethernet deployments.
