What happens when AP looses connection to cnMaestro?
Hello!
We are hosting a on premises VM cnMaestro. We are in the process of installing Cambium access points at a remote customer location. The connection to cnMaestro will be over a VPN connection.
We will be using cnPilot e410 & e510 access points.
What would happen if the VPN connection goes down or our VM server has a problem?
Would the access points stop working? We have no ACL configured and no RADIUS, all SSID’s will be regular WPA2/WPA3.
Thanks in advance.
Everythink will work normally :slight_smile:
Ok perfect, thank you for the quick reply!
