I am now working on the LINKPlanner to plan the Microwave 7GHz. What should be the generic value to input for the interfernece level?
Thank you in advance,
Tanyarit
Tanyarit
Hi Tanyarit, you typically don't need to check the interference box for licensed microwave PTP designs. Since it is licensed, it is assumed to be interference free and LINKPlanner accounts for thermal noise. Checking that box usually puts a value of -95dBm for licensed links.
I've attached a very old document that may help for the interference values.
Hi Chris_Fikert,
Thank you very much for your kind support,
Tanyarit
