Can someone at Camium tell us what the maximum throughput (download and upload speeds) one can achieve using a 5 Ghz ePMP AP and one ePMP1000 SM set up for standard TDD mode, 40 MB channel and 50/50 up/down.
This path is a line of sight shot of..3 miles (with no obstructions in between - just air. There is absolutely no interference on the selected frequency.
Just to clarify, this link is installed way out in the country, 40 miles from no-where, including the closest gopher.
Signal level at the SM is -50 Dbm. Signal to noise ratio is 55 DB. MCS downlink and uplink are both solid at 15..
What can one expect the maximum download and upload speeds to be (actual throughput)?
I am insterested in actual
