what is receiver sensitivity of Cambium 450m
@avdhut sapkale wrote:what is receiver sensitivity of Cambium 450m
Is this what you were after ?
This is for both 3GHz and 5GHz 450m (from spec sheet)
best regards,
Andy.
Or in Rx level, we need to consider bandwidth and frequency.
Below is a cut/paste from the user guide (ver 16.0.0.1,page 10-3)
best regards,
Andy.
Sensitivity
Nominal Receive Sensitivity (w/ FEC) @ 5 MHz Channel
5.1 GHz
1x=-101.6 dBm, 2x=-96.2 dBm, 4x=-90.2 dBm, 6x=-84 dBm, 8x=-76.6 dBm
5.2 GHz
1x=-101.3 dBm, 2x=-96.3 dBm, 4x=-89.7 dBm, 6x=-83.3 dBm, 8x=-75.7 dBm
5.4 GHz
1x=-101.1 dBm, 2x=-96.8 dBm, 4x=-90 dBm, 6x=-83.9 dBm, 8x=-76.2 dBm
5.8 GHz
1x=-101.6 dBm, 2x=-96.6 dBm, 4x=-89.9 dBm, 6x=-83.7 dBm, 8x=-76.3 dBm
Nominal Receive Sensitivity (w/ FEC) @ 10 MHz Channel
5.1 GHz
1x=-99 dBm, 2x=-94.6 dBm, 4x=-87.8 dBm, 6x=-81.6 dBm, 8x=-74.6 dBm
5.2 GHz
1x=-98.8 dBm, 2x=-93.8 dBm, 4x=-87.6 dBm, 6x=-81.4 dBm, 8x=-73.6 dBm
5.4 GHz
1x=-98.1 dBm, 2x=-94.1 dBm, 4x=-87.5 dBm, 6x=-81.5 dBm, 8x=-73.8 dBm
5.8 GHz
1x=-98.5 dBm, 2x=-93.6 dBm, 4x=-87.5 dBm, 6x=-81.2 dBm, 8x=-73.7 dBm
Nominal Receive Sensitivity (w/ FEC) @ 15 MHz Channel
5.1 GHz
1x=-97.3 dBm, 2x=-92.5 dBm, 4x=-86.3 dBm, 6x=-79.9 dBm, 8x=-72.9 dBm
5.2 GHz
1x=-96.7 dBm, 2x=-91.9 dBm, 4x=-85.7 dBm, 6x=-79.5 dBm, 8x=-72.5 dBm
5.4 GHz
1x=-96.2 dBm, 2x=-92.1 dBm, 4x=-85.5 dBm, 6x=-79.4 dBm, 8x=-72.4 dBm
5.8 GHz
1x=-97.2 dBm, 2x=-92.4 dBm, 4x=-85.5 dBm, 6x=-79.4 dBm, 8x=-72.5 dBm
Nominal Receive Sensitivity (w/ FEC) @ 20 MHz Channel
5.1 GHz
1x=-96.3 dBm, 2x=-91.9 dBm, 4x=-85.3 dBm, 6x=-79.3 dBm, 8x=-71.3 dBm
5.2 GHz
1x=-95.8 dBm, 2x=-91.8 dBm, 4x=-84.8 dBm, 6x=-78.8 dBm, 8x=-71.8 dBm
5.4 GHz
1x=-95.1 dBm, 2x=-91.4 dBm, 4x=-84.8 dBm, 6x=-78.3 dBm, 8x=-71.1 dBm
5.8 GHz
1x=-95.8 dBm, 2x=-91.3 dBm, 4x=-84.7 dBm, 6x=-78.3 dBm, 8x=-70.8 dBm
Nominal Receive Sensitivity (w/ FEC) @ 30 MHz Channel
5.1 GHz
1x=-93.1 dBm, 2x=-89.0 dBm, 4x=-83.0 dBm, 6x=-76.7 dBm, 8x=-69.8 dBm
5.2 GHz
1x=-93.1 dBm, 2x=-88.7 dBm, 4x=-82.5 dBm, 6x=-76.2 dBm, 8x=-69.4 dBm
5.4 GHz
1x=-93.6 dBm, 2x=-89.1 dBm, 4x=-82.9 dBm, 6x=-76.5 dBm, 8x=-69.7 dBm
5.8 GHz
1x=-94.1dBm, 2x=-89.4 dBm, 4x=-83.2 dBm, 6x=-76.8 dBm, 8x=-69.9 dBm
Nominal Receive Sensitivity (w/ FEC) @ 40 MHz Channel
5.1 GHz
1x=-92.1 dBm, 2x=-88.1 dBm, 4x=-82.0 dBm, 6x=-75.5 dBm, 8x=-68.2 dBm
5.2 GHz
1x=-92.0 dBm, 2x=-87.7 dBm, 4x=-81.7 dBm, 6x=-75.3 dBm, 8x=-67.9 dBm
5.4 GHz
1x=-92.7 dBm, 2x=-87.4 dBm, 4x=-81.8 dBm, 6x=-75.4 dBm, 8x=-68.2 dBm
5.8 GHz
1x=-93.0 dBm, 2x=-87.9 dBm, 4x=-82.1 dBm, 6x=-75.6 dBm, 8x=-68.1 dBm
and for 3GHz 450m
Sensitivity
3.5 GHz
1x=-97.3 dBm, 2x=-95.1 dBm, 4x=-88.7 dBm, 6x=-82.6 dBm, 8x=-74.9 dBm
3.6 GHz
1x=-96.6 dBm, 2x=-94.4 dBm, 4x=-88.0 dBm, 6x=-82.0 dBm, 8x=-74.2 dBm
3.5 GHz
1x=-94.9 dBm, 2x=-92.9 dBm, 4x=-86.4 dBm, 6x=-80.3 dBm, 8x=-73.2 dBm
3.6 GHz
1x=-94.3 dBm, 2x=-92.2 dBm, 4x=-85.8 dBm, 6x=-79.6 dBm, 8x=-72.3 dBm
3.5 GHz
1x=-93.1 dBm, 2x=-91.1 dBm, 4x=-84.6 dBm, 6x=-78.3 dBm, 8x=-71.9 dBm
3.6 GHz
1x=-92.6 dBm, 2x=-90.3 dBm, 4x=-84.0 dBm, 6x=-77.8 dBm, 8x=-71.2 dBm
3.5 GHz
1x=-92.0 dBm, 2x=-89.8 dBm, 4x=-83.3 dBm, 6x=-77.1 dBm, 8x=-68.7 dBm
3.6 GHz
1x=-91.3 dBm, 2x=-89.2 dBm, 4x=-82.7 dBm, 6x=-76.5 dBm, 8x=-69.9 dBm
3.5 GHz
1x=-90.2 dBm, 2x=-88.0 dBm, 4x=-81.5 dBm, 6x=-75.3 dBm, 8x=-68.7 dBm
3.6 GHz
1x=-89.5 dBm, 2x=-87.4 dBm, 4x=-80.9 dBm, 6x=-74.7 dBm, 8x=-68.1 dBm
3.5 GHz
1x=-89.0 dBm, 2x=-86.8 dBm, 4x=-80.3 dBm, 6x=-74.1 dBm, 8x=-67.5 dBm
3.6 GHz
1x=-88.3 dBm, 2x=-86.2 dBm, 4x=-79.7 dBm, 6x=-73.5 dBm, 8x=-66.9 dBm
