Why 30V Surge Arrestor ping lost?
I installed cnVision HUB and micro with 30V surge arrestor for my customer, but I found ping lost.
So I took off arrestor, the ping no lost, all work fine.
And I test the arrestor separate. PC1 ----> arrestor ----> PC2, ping lost. Why?
Sounds like a surge suppressor issue. Did you tried another SS ?
We bought more than 1 unit, but in my test, all units test result are the same. So I fell strange.
Could you share the SS specification or model number
Part Number is C000000L065A, 30 Volts, 0.01 Amp, bought from Cambium.
ping 32
This can happen due to grounding impedance mismatch. Are you using STP cable while connecting SS ?
It is recommended to use STP cable while using SS b/w PoE and radio.
Yes, I am using STP cables and the arrestor grounding. So I dont not why this happen.
Hi, Our support team is looking into this. We shall guide you through that channel.
