Why CnMatrix Ex2052-P CPU load suddenly goes to 100%?
We didn’t make any changes in configuration, and CPu load suddenly goes upto 100% and started flapping, then we need to reboot the switch and CPU load came back down to 7%. (Varies between 5-15%)
I had same problem with one of the E2052 last week.
After reboot it’s working normal.
Huge problem was to connect to the switch with gui, ssh.
90% ping lost, dropped ssh session.
After try #197 reboot was done.
Thanks Aman and Pshemo for reporting the high cpu utilization on cnMatrix. Engineering team is currently investigating it. The questions below would help our investigation.
  • What software version did you observe the high cpu usage? Had you seen this symptom on the same switch with previous version?
  • Was the symptom seen on multiple switches in the same network?
  • Do you run any mib tool or scanner such as Auvik to query the switch in your network?
  • Was switch accessible via SSH or serial console during this time? If so, please run the commands ‘show os stacktace’ and ‘show os cpu top’ (run this command a couple times), ‘show cpu-counter’. Please post the output of these commands.
We’ve had this happen and have gone over extensive troubleshooting with support with no resolution yet. The ticket 341091 is still open. Only way to resolve it appears to be a reboot.
Hi Tam,
we are running on 4.5-r3, yes we also faced same type of CPU load increasing in previous version. couple of months ago, almost all switches CPU load was high- at that time we need to reboot all switches and CPU load went back to normal condition.
We are not running any tool/scanner in our network.
we haven’t tried to access switch via SSH or console during that period.
  1. Soft 4.4-r3, no updateed from 6 months
  2. First time on this device. No observed on others in this network
  3. During high load ssh was able to connect in 197 try ! Ping Was 3000-5000, and 90% lost
4.No Auvik or other staff
  1. Command result
    ex2052-2p# show os cpu top
    Mem: 300268K used, 211616K free, 80784K shrd, 0K buff, 81048K cached
    CPU: 100% usr 0.0% sys 0.0% nic 0.0% idle 0.0% io 0.0% irq 0.0% sirq
    Load average: 0.00 0.00 0.00 1/108 2034
    PID PPID USER STAT VSZ %VSZ CPU %CPU COMMAND
    2032 2030 0 R 2452 0.4 0 0.0 /usr/bin/top -n2 -d2
    1153 1077 0 S 1028m205.7 0 0.0 {CFA} /usr/bin/ISS.exe
    1147 1077 0 S 1028m205.7 0 0.0 {TMR#} /usr/bin/ISS.exe
    1160 1077 0 S 1028m205.7 0 0.0 {AstT} /usr/bin/ISS.exe
    1163 1077 0 S 1028m205.7 0 0.0 {PoeT} /usr/bin/ISS.exe
    1197 1077 0 S 1028m205.7 0 0.0 {AA} /usr/bin/ISS.exe
    1198 1077 0 S 1028m205.7 0 0.0 {WSIF} /usr/bin/ISS.exe
    1196 1077 0 S 1028m205.7 0 0.0 {LLDP} /usr/bin/ISS.exe
    1171 1077 0 S 1028m205.7 0 0.0 {LNXT} /usr/bin/ISS.exe
    1180 1077 0 S 1028m205.7 0 0.0 {RAD} /usr/bin/ISS.exe
    1166 1077 0 S 1028m205.7 0 0.0 {SnpT} /usr/bin/ISS.exe
    1145 1077 0 S 1028m205.7 0 0.0 {ev} /usr/bin/ISS.exe
    1203 1077 0 S 1028m205.7 0 0.0 {EVLS} /usr/bin/ISS.exe
    1179 1077 0 S 1028m205.7 0 0.0 {OSPF} /usr/bin/ISS.exe
    1202 1077 0 S 1028m205.7 0 0.0 {DAL} /usr/bin/ISS.exe
    1193 1077 0 S 1028m205.7 0 0.0 {RMN2} /usr/bin/ISS.exe
    1156 1077 0 S 1028m205.7 0 0.0 {LNXS} /usr/bin/ISS.exe
    1164 1077 0 S 1028m205.7 0 0.0 {VLAN} /usr/bin/ISS.exe
    1146 1077 0 S 1028m205.7 0 0.0 {intTask.73} /usr/bin/ISS.exe
    1158 1077 0 S 1028m205.7 0 0.0 {L2DS} /usr/bin/ISS.exe
    1175 1077 0 S 1028m205.7 0 0.0 {ARP} /usr/bin/ISS.exe
    1200 1077 0 S 1028m205.7 0 0.0 {SNT} /usr/bin/ISS.exe
    1144 1077 0 S 1028m205.7 0 0.0 {intTask.72} /usr/bin/ISS.exe
    1333 1077 0 S 1028m205.7 0 0.0 {MSR} /usr/bin/ISS.exe
    1174 1077 0 S 1028m205.7 0 0.0 {RTM} /usr/bin/ISS.exe
    1168 1077 0 S 1028m205.7 0 0.0 {RT6} /usr/bin/ISS.exe
    1191 1077 0 S 1028m205.7 0 0.0 {HRT3} /usr/bin/ISS.exe
    2029 1077 0 S 1028m205.7 0 0.0 {C301} /usr/bin/ISS.exe
    1150 1077 0 S 1028m205.7 0 0.0 {CLIC} /usr/bin/ISS.exe
    1173 1077 0 S 1028m205.7 0 0.0 {LXMC} /usr/bin/ISS.exe
    1178 1077 0 S 1028m205.7 0 0.0 {SAT} /usr/bin/ISS.exe
    1167 1077 0 S 1028m205.7 0 0.0 {QOS} /usr/bin/ISS.exe
    1162 1077 0 S 1028m205.7 0 0.0 {LaTT} /usr/bin/ISS.exe
    1161 1077 0 S 1028m205.7 0 0.0 {PIf} /usr/bin/ISS.exe
    1186 1077 0 S 1028m205.7 0 0.0 {D6CL} /usr/bin/ISS.exe
    1188 1077 0 S 1028m205.7 0 0.0 {HST} /usr/bin/ISS.exe
    1165 1077 0 S 1028m205.7 0 0.0 {FLU} /usr/bin/ISS.exe
    1190 1077 0 S 1028m205.7 0 0.0 {HRT2} /usr/bin/ISS.exe
    1184 1077 0 S 1028m205.7 0 0.0 {DHC} /usr/bin/ISS.exe
    1187 1077 0 S 1028m205.7 0 0.0 {IGMP} /usr/bin/ISS.exe
    1157 1077 0 S 1028m205.7 0 0.0 {IPDB} /usr/bin/ISS.exe
    1169 1077 0 S 1028m205.7 0 0.0 {LI6T} /usr/bin/ISS.exe
    1177 1077 0 S 1028m205.7 0 0.0 {RIP} /usr/bin/ISS.exe
    1189 1077 0 S 1028m205.7 0 0.0 {HRT1} /usr/bin/ISS.exe
    1192 1077 0 S 1028m205.7 0 0.0 {RMON} /usr/bin/ISS.exe
    1149 1077 0 S 1028m205.7 0 0.0 {SMT} /usr/bin/ISS.exe
    1152 1077 0 S 1028m205.7 0 0.0 {VcmT} /usr/bin/ISS.exe
    1182 1077 0 S 1028m205.7 0 0.0 {DHS} /usr/bin/ISS.exe
    1183 1077 0 S 1028m205.7 0 0.0 {DHRL} /usr/bin/ISS.exe
    1201 1077 0 S 1028m205.7 0 0.0 {DNSR} /usr/bin/ISS.exe
    1151 1077 0 S 1028m205.7 0 0.0 {PKTT} /usr/bin/ISS.exe
    1159 1077 0 S 1028m205.7 0 0.0 {CFAT} /usr/bin/ISS.exe
    1170 1077 0 S 1028m205.7 0 0.0 {PNG6} /usr/bin/ISS.exe
    1176 1077 0 S 1028m205.7 0 0.0 {PNG} /usr/bin/ISS.exe
    1181 1077 0 S 1028m205.7 0 0.0 {TACT} /usr/bin/ISS.exe
    1185 1077 0 S 1028m205.7 0 0.0 {DCS} /usr/bin/ISS.exe
    1194 1077 0 S 1028m205.7 0 0.0 {CTS} /usr/bin/ISS.exe
    1195 1077 0 S 1028m205.7 0 0.0 {SSH} /usr/bin/ISS.exe
    1199 1077 0 S 1028m205.7 0 0.0 {cnAg} /usr/bin/ISS.exe
    1204 1077 0 S 1028m205.7 0 0.0 {ExtL} /usr/bin/ISS.exe
    1205 1077 0 S 1028m205.7 0 0.0 {RLD} /usr/bin/ISS.exe
    1707 1137 0 S 18484 3.6 0 0.0 /usr/bin/device-agent
    1135 1077 0 S 2664 0.5 0 0.0 /usr/bin/udevd
    1141 1135 0 S 2660 0.5 0 0.0 /usr/bin/udevd
    1441 1135 0 S 2660 0.5 0 0.0 /usr/bin/udevd
    2034 2030 0 S 2452 0.4 0 0.0 head -c-2
    2030 1138 0 S 2448 0.4 0 0.0 sh -c export LINES=100;export COLU
    MNS=100;echo -n ‘H’|
    2033 2030 0 S 2448 0.4 0 0.0 tail -n+2
    1 0 0 S 2364 0.4 0 0.0 init
    1077 1 0 S 2364 0.4 0 0.0 {init.sh} /bin/sh /etc/init.sh
    1127 1077 0 S 2364 0.4 0 0.0 sh /etc/pushbutton.sh
    1137 1077 0 S 2364 0.4 0 0.0 sh /etc/cda.sh
    1126 1077 0 S < 2168 0.4 0 0.0 /usr/bin/swWdog
    1131 1127 0 S 2148 0.4 0 0.0 /usr/bin/pushbutton
    7 2 0 SW 0 0.0 0 0.0 [rcu_sched]
    221 2 0 SW 0 0.0 0 0.0 [kworker/0:1]
    3 2 0 SW 0 0.0 0 0.0 [ksoftirqd/0]
    994 2 0 SW 0 0.0 0 0.0 [irq/31-f10d0000]
    431 2 0 SW 0 0.0 0 0.0 [kworker/u2:3]
    16 2 0 SW 0 0.0 0 0.0 [kworker/u2:2]
    10 2 0 SW 0 0.0 0 0.0 [kdevtmpfs]
    2 0 0 SW 0 0.0 0 0.0 [kthreadd]
    5 2 0 SW< 0 0.0 0 0.0 [kworker/0:0H]
    8 2 0 SW 0 0.0 0 0.0 [rcu_bh]
    9 2 0 SW 0 0.0 0 0.0 [migration/0]
    11 2 0 SW< 0 0.0 0 0.0 [perf]
    14 2 0 SW< 0 0.0 0 0.0 [writeback]
    219 2 0 SW< 0 0.0 0 0.0 [crypto]
    220 2 0 SW< 0 0.0 0 0.0 [bioset]
    223 2 0 SW< 0 0.0 0 0.0 [kblockd]
    231 2 0 SW< 0 0.0 0 0.0 [ata_sff]
    338 2 0 SW< 0 0.0 0 0.0 [rpciod]
    351 2 0 SW 0 0.0 0 0.0 [kswapd0]
    352 2 0 SW< 0 0.0 0 0.0 [vmstat]
    353 2 0 SW 0 0.0 0 0.0 [fsnotify_mark]
    354 2 0 SW< 0 0.0 0 0.0 [nfsiod]
    CPU Total Receive Counters
    Unicast Packets : 98736
    Multicast Packets : 593738
    Broadcast Packets : 108045
    ARP Packets : 92883
    IGMP Packets : 190037
    IP Multicast Packets : 55149
    STP Packets : 238895
    LLDP Packets : 109657
    DHCP Packets : 101
    Other Packets : 113797
And same thing again.
100% CPU, barely restarted it yesterday.
Same thing today for several minutes
For now, I’m getting on this switch, but what will happen in a moment.
Everything except access via SSH and WEB and ping works
All devices are up and running, only the administration interface is just not responding and the pings are either 7000 or 4000 and a loss of 99%.
Mem: 301616K used, 210268K free, 80800K shrd, 0K buff, 81064K cached
CPU: 24.1% usr 75.8% sys 0.0% nic 0.0% idle 0.0% io 0.0% irq 0.0% sirq
Load average: 1.40 1.35 1.33 2/108 4301
1190 1076 0 R 1028m205.7 0 68.7 {HRT3} /usr/bin/ISS.exe
1125 1076 0 S < 2168 0.4 0 27.1 /usr/bin/swWdog
4299 4297 0 R 2452 0.4 0 0.9 /usr/bin/top -n2 -d2
1152 1076 0 S 1028m205.7 0 0.4 {CFA} /usr/bin/ISS.exe
1146 1076 0 S 1028m205.7 0 0.4 {TMR#} /usr/bin/ISS.exe
1159 1076 0 S 1028m205.7 0 0.4 {AstT} /usr/bin/ISS.exe
1155 1076 0 S 1028m205.7 0 0.4 {LNXS} /usr/bin/ISS.exe
7 2 0 SW 0 0.0 0 0.4 [rcu_sched]
3 2 0 SW 0 0.0 0 0.4 [ksoftirqd/0]
1162 1076 0 S 1028m205.7 0 0.0 {PoeT} /usr/bin/ISS.exe
1197 1076 0 S 1028m205.7 0 0.0 {WSIF} /usr/bin/ISS.exe
1196 1076 0 S 1028m205.7 0 0.0 {AA} /usr/bin/ISS.exe
1195 1076 0 S 1028m205.7 0 0.0 {LLDP} /usr/bin/ISS.exe
1165 1076 0 S 1028m205.7 0 0.0 {SnpT} /usr/bin/ISS.exe
1192 1076 0 S 1028m205.7 0 0.0 {RMN2} /usr/bin/ISS.exe
1179 1076 0 S 1028m205.7 0 0.0 {RAD} /usr/bin/ISS.exe
1170 1076 0 S 1028m205.7 0 0.0 {LNXT} /usr/bin/ISS.exe
1144 1076 0 S 1028m205.7 0 0.0 {ev} /usr/bin/ISS.exe
1202 1076 0 S 1028m205.7 0 0.0 {EVLS} /usr/bin/ISS.exe
1178 1076 0 S 1028m205.7 0 0.0 {OSPF} /usr/bin/ISS.exe
1201 1076 0 S 1028m205.7 0 0.0 {DAL} /usr/bin/ISS.exe
1163 1076 0 S 1028m205.7 0 0.0 {VLAN} /usr/bin/ISS.exe
1145 1076 0 S 1028m205.7 0 0.0 {intTask.73} /usr/bin/ISS.exe
1137 1076 0 S 1028m205.7 0 0.0 /usr/bin/ISS.exe
1157 1076 0 S 1028m205.7 0 0.0 {L2DS} /usr/bin/ISS.exe
1174 1076 0 S 1028m205.7 0 0.0 {ARP} /usr/bin/ISS.exe
1143 1076 0 S 1028m205.7 0 0.0 {intTask.72} /usr/bin/ISS.exe
1332 1076 0 S 1028m205.7 0 0.0 {MSR} /usr/bin/ISS.exe
1199 1076 0 S 1028m205.7 0 0.0 {SNT} /usr/bin/ISS.exe
1173 1076 0 S 1028m205.7 0 0.0 {RTM} /usr/bin/ISS.exe
1167 1076 0 S 1028m205.7 0 0.0 {RT6} /usr/bin/ISS.exe
1189 1076 0 S 1028m205.7 0 0.0 {HRT2} /usr/bin/ISS.exe
4290 1076 0 S 1028m205.7 0 0.0 {C301} /usr/bin/ISS.exe
1149 1076 0 S 1028m205.7 0 0.0 {CLIC} /usr/bin/ISS.exe
1177 1076 0 S 1028m205.7 0 0.0 {SAT} /usr/bin/ISS.exe
1161 1076 0 S 1028m205.7 0 0.0 {LaTT} /usr/bin/ISS.exe
1166 1076 0 S 1028m205.7 0 0.0 {QOS} /usr/bin/ISS.exe
1188 1076 0 S 1028m205.7 0 0.0 {HRT1} /usr/bin/ISS.exe
1160 1076 0 S 1028m205.7 0 0.0 {PIf} /usr/bin/ISS.exe
1187 1076 0 S 1028m205.7 0 0.0 {HST} /usr/bin/ISS.exe
1164 1076 0 S 1028m205.7 0 0.0 {FLU} /usr/bin/ISS.exe
1185 1076 0 S 1028m205.7 0 0.0 {D6CL} /usr/bin/ISS.exe
1186 1076 0 S 1028m205.7 0 0.0 {IGMP} /usr/bin/ISS.exe
1156 1076 0 S 1028m205.7 0 0.0 {IPDB} /usr/bin/ISS.exe
1168 1076 0 S 1028m205.7 0 0.0 {LI6T} /usr/bin/ISS.exe
1176 1076 0 S 1028m205.7 0 0.0 {RIP} /usr/bin/ISS.exe
1183 1076 0 S 1028m205.7 0 0.0 {DHC} /usr/bin/ISS.exe
1191 1076 0 S 1028m205.7 0 0.0 {RMON} /usr/bin/ISS.exe
1148 1076 0 S 1028m205.7 0 0.0 {SMT} /usr/bin/ISS.exe
1151 1076 0 S 1028m205.7 0 0.0 {VcmT} /usr/bin/ISS.exe
1181 1076 0 S 1028m205.7 0 0.0 {DHS} /usr/bin/ISS.exe
1182 1076 0 S 1028m205.7 0 0.0 {DHRL} /usr/bin/ISS.exe
1184 1076 0 S 1028m205.7 0 0.0 {DCS} /usr/bin/ISS.exe
1200 1076 0 S 1028m205.7 0 0.0 {DNSR} /usr/bin/ISS.exe
1150 1076 0 S 1028m205.7 0 0.0 {PKTT} /usr/bin/ISS.exe
1158 1076 0 S 1028m205.7 0 0.0 {CFAT} /usr/bin/ISS.exe
1169 1076 0 S 1028m205.7 0 0.0 {PNG6} /usr/bin/ISS.exe
1172 1076 0 S 1028m205.7 0 0.0 {LXMC} /usr/bin/ISS.exe
1175 1076 0 S 1028m205.7 0 0.0 {PNG} /usr/bin/ISS.exe
1180 1076 0 S 1028m205.7 0 0.0 {TACT} /usr/bin/ISS.exe
1193 1076 0 S 1028m205.7 0 0.0 {CTS} /usr/bin/ISS.exe
1194 1076 0 S 1028m205.7 0 0.0 {SSH} /usr/bin/ISS.exe
1198 1076 0 S 1028m205.7 0 0.0 {cnAg} /usr/bin/ISS.exe
1203 1076 0 S 1028m205.7 0 0.0 {ExtL} /usr/bin/ISS.exe
1204 1076 0 S 1028m205.7 0 0.0 {RLD} /usr/bin/ISS.exe
1700 1136 0 S 18484 3.6 0 0.0 /usr/bin/device-agent
1134 1076 0 S 2664 0.5 0 0.0 /usr/bin/udevd
1140 1134 0 S 2660 0.5 0 0.0 /usr/bin/udevd
1440 1134 0 S 2660 0.5 0 0.0 /usr/bin/udevd
4301 4297 0 S 2452 0.4 0 0.0 head -c-2
4297 1137 0 S 2448 0.4 0 0.0 sh -c export LINES=100;export COLU
4300 4297 0 S 2448 0.4 0 0.0 tail -n+2
1076 1 0 S 2364 0.4 0 0.0 {init.sh} /bin/sh /etc/init.sh
1126 1076 0 S 2364 0.4 0 0.0 sh /etc/pushbutton.sh
1136 1076 0 S 2364 0.4 0 0.0 sh /etc/cda.sh
1133 1126 0 S 2148 0.4 0 0.0 /usr/bin/pushbutton
993 2 0 SW 0 0.0 0 0.0 [irq/31-f10d0000]
6 2 0 SW 0 0.0 0 0.0 [kworker/u2:0]
ex2052-2p# show cpu-counter
Unicast Packets : 58889
Multicast Packets : 254313
Broadcast Packets : 36004
ARP Packets : 35667
IGMP Packets : 39561
IP Multicast Packets : 80586
STP Packets : 91461
LLDP Packets : 42705
DHCP Packets : 101
Other Packets : 59125
ex2052-2p# show os stacktrace
0xb694e720 in nanosleep () from /lib/libc.so.6
Thread 61 (LWP 4290):
#0 0xb694e200 in waitpid () from /lib/libc.so.6
#1 0xb68ef36c in ?? () from /lib/libc.so.6
#2 0xb68ef928 in system () from /lib/libc.so.6
#3 0x01658c4c in OsixGetCmdOutput ()
#4 0x01852c58 in cli_process_os_cmd ()
#5 0x007f6580 in mmi_action_procedure ()
#6 0x0084fa00 in CliExecuteCommand ()
#7 0x0082824c in CliProcessCommand ()
#8 0x00823c1c in CliMainProcess ()
#9 0x00864e28 in CliSshTaskStart ()
#10 0x020bbdb4 in ?? ()
#11 0xb6ea2e8c in ?? () from /lib/libpthread.so.0
#12 0xb6981f08 in ?? () from /lib/libc.so.6
Backtrace stopped: previous frame identical to this frame (corrupt stack?)
Thread 60 (LWP 1332):
#0 0xb6ea7aa8 in pthread_cond_wait () from /lib/libpthread.so.0
#1 0x020bb938 in osSemWait ()
#2 0x01656c10 in OsixEvtRecv ()
#3 0x019ec420 in MibSaveTaskMain ()
#4 0x020bbdb4 in ?? ()
#5 0xb6ea2e8c in ?? () from /lib/libpthread.so.0
#6 0xb6981f08 in ?? () from /lib/libc.so.6
Thread 59 (LWP 1204):
#3 0x0165e820 in RELOAD_taskEntry ()
Thread 58 (LWP 1203):
#0 0xb6a12c1c in mq_timedreceive () from /lib/librt.so.1
#1 0xb6a12ad8 in mq_receive () from /lib/librt.so.1
#2 0x01636560 in sysLogExtProc ()
#3 0x020bbdb4 in ?? ()
#4 0xb6ea2e8c in ?? () from /lib/libpthread.so.0
#5 0xb6981f08 in ?? () from /lib/libc.so.6
Thread 57 (LWP 1202):
#0 0xb697b114 in select () from /lib/libc.so.6
#1 0xb697b108 in select () from /lib/libc.so.6
#2 0x04b67bd0 in ?? ()
Thread 56 (LWP 1201):
#2 0x04964f88 in CDAIF_traceFlag ()
Thread 55 (LWP 1200):
#3 0x00c2bb78 in DnsResolverMainTask ()
Thread 54 (LWP 1199):
#3 0x015fa670 in SntpMain ()
Thread 53 (LWP 1198):
#0 0xb6eab4a8 in recvfrom () from /lib/libpthread.so.0
#1 0xb6eab49c in recvfrom () from /lib/libpthread.so.0
#2 0x00000152 in ?? ()
Thread 52 (LWP 1197):
#2 0x04a7796c in gLastSyncSuccessful ()
Thread 51 (LWP 1196):
#3 0x0056fa30 in AA_Main ()
Thread 50 (LWP 1195):
#3 0x004b5768 in LldpMainTask ()
Thread 49 (LWP 1194):
#3 0x00864758 in CliSshTaskMain ()
Thread 48 (LWP 1193):
#3 0x0085764c in CliTelnetTaskMain ()
Thread 47 (LWP 1192):
#3 0x0165a1a4 in OsixReceiveEvent ()
#4 0x0103a58c in Rmon2MainTask ()
#5 0x020bbdb4 in ?? ()
#6 0xb6ea2e8c in ?? () from /lib/libpthread.so.0
#7 0xb6981f08 in ?? () from /lib/libc.so.6
Thread 46 (LWP 1191):
#3 0x00ffc870 in RmonMain ()
Thread 45 (LWP 1190):
#0 0xb6a12b60 in mq_timedsend () from /lib/librt.so.1
#1 0xb6e0c638 in petWatchdogVersion () from /usr/lib/libswd.so
#2 0xb6e0c8d0 in petWatchdog () from /usr/lib/libswd.so
#3 0x016bb468 in SelectWrapper ()
#4 0x00c1364c in HttpGetChar ()
#5 0x00c13b88 in HttpProcessReqLine ()
#6 0x00c1211c in ProcessHttpReq ()
#7 0x00c10ce8 in HttpStartProcessing ()
#8 0x00c10a28 in HttpProcHandleWakeUpEvent ()
#9 0x00c10888 in HttpProcessMain ()
Thread 44 (LWP 1189):
#3 0x00c1084c in HttpProcessMain ()
Thread 43 (LWP 1188):
Thread 42 (LWP 1187):
#3 0x00c105b0 in HttpMain ()
Thread 41 (LWP 1186):
#3 0x00ea9b10 in IgmpTaskMain ()
Thread 40 (LWP 1185):
#3 0x008e8a8c in D6ClMainTask ()
Thread 39 (LWP 1184):
#2 0x00000000 in ?? ()
Thread 38 (LWP 1183):
#3 0x0088e5ac in DhcpCTaskMain ()
Thread 37 (LWP 1182):
#3 0x008ceb68 in DhcpRelayMain ()
Thread 36 (LWP 1181):
#3 0x008ad478 in DhcpTaskMain ()
Thread 35 (LWP 1180):
#3 0x00f85428 in TacacsClientMain ()
Thread 34 (LWP 1179):
Thread 33 (LWP 1178):
#4 0x00dbd974 in OSPFTaskMain ()
Thread 32 (LWP 1177):
#4 0x011c8984 in SnmpMain ()
Thread 31 (LWP 1176):
#4 0x00fb9308 in RIPTaskMain ()
Thread 30 (LWP 1175):
#3 0x009abb5c in PingTaskMain ()
Thread 29 (LWP 1174):
#3 0x0087c19c in ArpTaskMain ()
Thread 28 (LWP 1173):
#3 0x0098ae64 in RtmTaskMain ()
Thread 27 (LWP 1172):
#0 0xb6eab550 in recvmsg () from /lib/libpthread.so.0
#1 0xb6eab544 in recvmsg () from /lib/libpthread.so.0
#2 0x00000010 in ?? ()
Thread 26 (LWP 1170):
#3 0x00971a5c in LnxIpMain ()
Thread 25 (LWP 1169):
#3 0x00a80540 in Ping6TaskMain ()
Thread 24 (LWP 1168):
#3 0x009dfc84 in Lip6MainInit ()
Thread 23 (LWP 1167):
#4 0x009f3f80 in Rtm6TaskMain ()
Thread 22 (LWP 1166):
#3 0x01acbda4 in QoSInit ()
Thread 21 (LWP 1165):
#3 0x01214090 in SnoopMain ()
Thread 20 (LWP 1164):
#4 0x00d2245c in VlanFlushTaskMain ()
Thread 19 (LWP 1163):
#3 0x013ea8f8 in VlanMain ()
Thread 18 (LWP 1162):
#0 0xb6eaba30 in nanosleep () from /lib/libpthread.so.0
#1 0xb6eaba24 in nanosleep () from /lib/libpthread.so.0
Thread 17 (LWP 1161):
#3 0x01371470 in LaMain ()
Thread 16 (LWP 1160):
#3 0x0133ab00 in PnacInterfaceTaskMain ()
Thread 15 (LWP 1159):
#3 0x0108dc30 in AstTaskMain ()
Thread 14 (LWP 1158):
#3 0x00696ad4 in CfaPacketTxTask ()
Thread 13 (LWP 1157):
#4 0x006f5778 in L2DSMain ()
Thread 12 (LWP 1156):
#4 0x006ddef4 in IPDBMain ()
Thread 11 (LWP 1155):
Thread 10 (LWP 1152):
#3 0x0066ff14 in CfaMain ()
Thread 9 (LWP 1151):
#3 0x005e3e5c in VcmTaskMain ()
Thread 8 (LWP 1150):
#3 0x0069664c in CfaPeriodicPktTxTsk ()
Thread 7 (LWP 1149):
#0 0xb6eaafe0 in read () from /lib/libpthread.so.0
#1 0xb6eaafd4 in read () from /lib/libpthread.so.0
#2 0x03aaab44 in gCliSessions ()
Thread 6 (LWP 1148):
#3 0x0162be70 in SysLogSmtpMain ()
Thread 5 (LWP 1146):
#2 0x00002710 in ?? ()
Thread 4 (LWP 1145):
#0 0xb6eaafe4 in read () from /lib/libpthread.so.0
#1 0x020ab0f0 in ?? ()
#2 0x020bbdb4 in ?? ()
#3 0xb6ea2e8c in ?? () from /lib/libpthread.so.0
#4 0xb6981f08 in ?? () from /lib/libc.so.6
Thread 3 (LWP 1144):
#2 0x020562fc in cpssEventSelect ()
#3 0x00cc63d4 in IssCpssEventHandler ()
Thread 2 (LWP 1143):
Thread 1 (LWP 1137):
#0 0xb694e720 in nanosleep () from /lib/libc.so.6
#1 0xb694e714 in nanosleep () from /lib/libc.so.6
There is a probable cause!
It starts to happen when there is no internet connection for a long time. So at least 20 minutes up.
Thank you. We will analyze the traces.
Can you also post the ‘show running-config’?
Have you had any snmp sweeps or security compliance scanners ?
I have some customers where their flavor of NMS / Compliance Software will sometimes trigger this 100% bug at times.
Hi, reading this thread I took a look on my switch EX2010P and it he was on also 100% CPU dont know how many days I didnt notice any packet loss or something … reboot fixed it ! Fw 4.3.r3 !
This is a hotel. I have a total of 10 matrixes installed in it. This is the only thing that happens to this one.
They are all in one group with the same configuration and the same hardware.
I have SNMP turned off completely, there is no NMS in the network.
As I wrote, it starts to happen after there is no internet for a while?
the swWdog process seems to be firing something that kills the system.
We’ve got similar issues with our switch where high CPU is related to “/usr/bin/ISS.exe”. Other than rebooting the switch, was there a permanent fix found?
This is a production switch so it’s not something I’m able to reboot easily during the day.
I did’t observe this issue on 5.0.1 :slight_smile:
They’ve resolved the 100% CPU issues in R5.0.1-R4:
5.0.1-r4 included a fix for 100% cpu condition as described in the RN. It was reproducible in our engineering lab. 5.0.1-r4 also included improvements for cpu performance. There may be other cases that cause high cpu usage. We will continue to improve cpu utilization in the future releases.
We have 50 to 60 cnMatrix switches on our network, and we are still experiencing the 100% CPU utilization issue. I will be opening another support case on this tomorrow when I’m back in the office. I’m unable to capture any tech support logs since the switch keeps ending my remote session. We’ve had 2 to 3 switches running version 5.0.1-r4 experience this issue in the last two months. Is anyone else still experiencing this issue besides us?
Any word on this yet?
We have a ticket open with technical support and are actively troubleshooting the issue. They have acknowledged the problem, and it is currently being investigated by the cnMatrix engineering team. I would urge you to open a ticket as well, so they are aware that others are having the issue. I will let you know if I make any progress on my end though.
