Hello,
has anyone tried to configure the WiFi4EU snippet using the C4000 controller? It is not clear to me why the supplier where I bought the Cambium devices advised me to configure the WIFI4EU authentication system in the cloud and to avoid doing it on the C4000, do you know if there are documented problems for this type of configuration on the controller?
Thank you
Question, why would you even do it on C4000?
KR
@alfonsof , WiFi4EU is best supported in Cloud and you get the best experience also there.
C4000 is end-of-life’d and some of these features were not certified on C4000, unfortunately.
