Hello,
i’m deploying a wire replacement solution with N500 450MHz (monitoring a valve). the topology is PMP with an AP and two EP. I’m wondering if I can use wire replacement from one EP to another (or this is a PTP solution, only) how can I configure the network? (should I enable “bounce” for this network?)
