noticed the mac address both wlan and lan changes ( + 1 ) when upgrading from 2.1 to 2.3 !!
is this expected behaviour? i'm using radius with mac autentication in the ap and this causes trouble to the sm.
also I have some APs with the country code "other" and after upgrade complain about the license, and they require a new licence, adjusting parameters (freq and power), then applying new license, then adjusting back the levels.
Very unfortunate but this is actually a bug in 2.3 that we are working very hard to fix ASAP. In the meantime, I will have to ask you to go through the following work around -
1) If you are using Radius and MAC authentication, in the short term you will have to use the new MAC address to continue to use Radius
2) For the licensing issue you will have to generate a new license key based off the new MAC address
We will fix this issue but if it is too much of a headache to run this way with 2.3, I would suggest you keep your sstem at 2.2 until we have 2.3.1 available.
