Do WIRELESS MANAGER support PTP670 as well?
What is the pricing for node ranging between 1-200?
Thank you and more power!
Yes.
WM supports PTP 670 device type as well. Currently, the support is on it's way to release by 3rd week of September and will be available on Cambium support site.
Regarding the pricing details - Please raise a request/query on https://support.cambiumnetworks.com/
Let us know in case of any query.
Regards,
Jayshree Harinkhede
Hi.
Is there a list of supported devices? I was checking release notes, but I can't find that information.
Kind regards
Hi AnzeZ,
The list of supported devices in WM 4.5.6 are added in Wireless Manager 4.5 Release Notes under 2.1 All Supported Elements.
You can download the release note from https://support.cambiumnetworks.com/files/wireless%20manager/
The devices support which are added in WM after WM 4.5.6 release are available as Hotfix on above link which have devices like PTP 550, PTP 670,PTP 820, PMP 450b, PTP 450b, PMP 450m, etc.
Regards,
Jayshree Harinkhede
