E400 has the same error wwan not found…
Please could you describe your setup? What software version are you running, and where you you seeing this message?
Whenever I debug the AP. It says after some lines. It gives an error of wwan not found. Secondly I reseted them all , still same. Error.
I use my cambium AP as an AP on my lan side.
Simple network.
Yet I can’t get any wired lan info.
When I debug from cnmaestro, it says wwan not found.
Unless someone from the community has any suggestions, I would recommend that you raise a support ticket at https://help.cambiumnetworks.com/hc/requests/new
I’ve sent the mail. I have many issues. As iam not much into cambium and it’s frustrating at times with an indepth network. I am confused now. After the updates at mikrotik that won’t communicate. At wifi level. It chokes my cambium APs. And it’s radio start only then … plus these I’ve reset the device’s yet issues .
