This is the 3rd time its done this. I had it unplugged to test something else. Power it back on and its radios don’t enable.
Last time I hit the sync button in CNM.
This time I am gonna try “reboot” from tools.
EDIT: That worked.
EDIT: That worked.
Same here. We have 2 devices is the network and both behave same way. After reboot, radios are OFF, but in the configuration tab it says they are ENABLED. After reboot radios are back ON again. Both devices have latest firmware version 7.0-r5 and there is no newer one available.
@Cambum Support, please fix this issue ASAP! It’s not acceptable for newest devices to have such bug and issue in software!
I should have probably followed up on this. This is a feature of the latest firmwares. It’s to address not having enough power for the radios to start. If the unit reboots three times in 24 hours, it will disable the radios, thinking that there isn’t enough power. After some amount of time it’s supposed to re-enable them. I recommended that the radios blink SOS when in this state. So there is a visual cue as to why the radio isn’t accepting clients.
