XV2-2T have one RJ45 port with power out for connect to other PoE devices. For the case, can the connection on this situation?
Primary XV2-2T with AC power point that connect to secondary XV2-2T, the second devices connect to the third XV2-2T which can create a total 200 meters long WiFi network with single power point? thanks.
The PoE Out is 30 watts for the XV2-2T APs. The AP itself can draw up to 20 watts so you would need to use a PoE switchport that can deliver up to 50 watts of PoE power or use the 60 watt Cambium PoE injector.
the N000000L142A is 60W power supply so, yes it will work. Each XV2-2T0 can draw up to 20W and the XV2-2T0 PoE-Out port can supply up to 30W so total max draw would be 40W for the two APs.
