XV3-8 Wi-Fi 6 Access Point
Good morning
Can you help me by indicating the model of the new Wi-Fi access point to replace the XV3-8 Wi-Fi 6 model?
And what would be the reference of the compatible poe source for the new wifi access points
Thank you!
@Tecpetrol_Sistemas_C , XV3-8 is a new AP, and we do not have anything that is planned to replace it. What capabilities are you looking for specifically? I can help find the right AP for you.
XE5-8 is a complementary product to the XV3-8 which has two additional SDR radios along with 6GHz band support. So if you are looking for a more powerful AP platform as compared to the powerful XV3-8 it would currently be the XE5-8.
Can you please tell me the recommended PoE source model for the XV3-8?
we recommend our passive injector N000000L142A or use a powered Ethernet switch that is 802.3bt type 3 or higher capable. Our data sheet lists the power injector for your reference:
